GF-9191 Shield Plate Replacement?
mcroce
Hi, I just bought a fairly good condition Sharp GF-9191H off of eBay.
I've gotten it completely disassembled to clean it up.
During the disassembly, the cardboard backed shield plate on the inside of the device came off a little worse for wear - it's probably still usable, but I'd like to replace it if possible.
Does anyone know of a source to replace them, or can I make one with aluminum foil and cardboard cut to the right shape?
Thanks!
Matt
Thanks!
Matt
That might be your best bet. I don't know what cheap cardboard they used back then, but some of those shields just disintegrate if you breathe on them the wrong way.
I found out recently, because of this topic, that the foil on cardboard isn't necessarily a shield. A lot of times it was an internal antenna to help with AM or SW reception. How about that. :cool:
Where'd you hear that Bobby, I'd be interested to see it if such a topic exists. In this case, it's virtually certain to be an RF shield, as it's grounded and a flat plate makes a horrible AM or SW antenna & being right above a circuit board, would probably pick up all kinds of electrical noise, except the actual radio signal you will be wanting.
