Gf-9000 transformer voltage and amperage output?
Obuffalo
Hi trying to resto a 9000, originally I had not much except a buzzing on the unit. I replaced the power amp chip and a couple caps on the power amp board and now when I switch the unit on I get a faint hissing from the speakers and some faint crackling when I slide the volume. There's no lights, when I power on but tape spins when press play, FF ect. The guy I got it from said the transformer blew when he put 240v through the 110v side (not sure) however it puts out 17v with the mains and 16v on the battery. I haven't tested the amperage yet. Can someone let me know their readings for there's please so I can either move on or take it to the nearest shooting range.
Boomboxholic
Dirty switches might cause sound issues, so you have to spray off some contact cleaner on all the switches and recording bar if not already.
Radio raheem
Requiem Æternam
is it possible the speakers are blown? quite common with this model, try her on headphones and see if you have a better result
Obuffalo
hi thanks for the replies. ive tried all avenues such as using external speakers, external audio source, external speakers just hiss too and the same via phono. also power light doesnt come on.
