GE 3-5266 owners: Question about noise level in play mode
sp1068
Hi. Before I get any deeper into this unit (and it's not too much of a picnic to service), can anyone with one of these boomboxes tell me for sure if the noise level in play mode is just normally very high with these? Just in play mode, with no tape?
I have other GEs of about the same age (3-5252, 3-5263), and they don't have this much noise. Have replaced the preamp chip (LA3220) with a replacement NTE 1634, and no difference. The 5 volts that feeds the chip is clean. I'm leaning toward "It must be normal", even if I find it unacceptably high noise. Combination hiss, with some lower frequency roar. Tapes play at the correct volume level, with no abnormally high gain, etc. This issue almost has to be the way the chip is designed, even though it's classified as "low noise".
Btw, it's not the motor. The noise doesn't change with the motor disconnected. And it's not a magnetized head, or tape path. Thanks.
sp1068
It's not the I.C. Can float the inverting input pins, and it's silent. Looking for a source for a schematic I can download. Sams looks like it's mail only for that model. It's hard to trace anything with no real markings on the board.
IvyDouglas
If you're hearing static or hum in play mode, it could be aging electronics or signal interference. Upgrading to a stable component like the IS7000 can help reduce electrical noise, improving playback quality in vintage audio setups.
Any update?
