Heyya, =)
I know blasting a switch with detox cleaner will sometimes restore a switch after it gets gummed up but what do you do when a switch is loose. I have a GF-777Z with a flaky 'FUNCTION' toggle that switches the input between line-in, tuner or tape. It feels a little loose & the left side cuts in & out when you wiggle it sideways. To me that seems to me to be a loose switch, not dirty. How do you get to it & fix it? I don't look forward to disassembling all those plastic pieces & circuits.
