FH-909r cassette deck / light
Timecop1987
I made myself an early christmas gift and bought me a Sony FH-909r main unit, including the optional CD-player - yay! Also found matching speakers and the remote.
The issues are as following:
1 - the cassette deck opens smooth, but when closing it wont fit right back into the housing - a gentle push helps, but i‘d like to get it 100%. any ideas?
2 - nearly all lights are working, except for the one inside the cassette deck - can anyone get me an info an a replacement bulb/LED - is the deck „easy“ to fix?
thanks in advance!!
(pics will follow after the speakers arrive)
ford93
Hopefully some member here that are familiar with these can help you.
Good luck and congrats.
Timecop1987
Thanks for the heads up guys!
I just changed the bulb and now there is light!! Pretty easy to access the different decks.
The tapedeck still has troubles inserting..I may try oiling the mechanism. Can‘t wait to get my speakers and crank that thing up!
Timecop1987
sorted everything out! I am so happy with the results - what a great looking & sounding box!! Will put up Pics later!!
