Def Leppard Theme Boombox!
You heard right, with the help of my son Billy we are customizing an M70 just like Chris did, except with a Def Leppard theme. I was very lucky to get a free M70 from member DJ Will. Thankyou again Will. ;-) Pics to follow!!!
OH MAN.....Can't wait to see this!
:popcorn:
Thanks guys!!! This is what face looks like right now. Will painted it blue already. You guys know me though i usually like original oem look although i have always wanted to try this and was waiting for perfect opportunity and think this will be it. ;-)
First my son Billy sanded the finish and taped up areas not getting painted. He put 3 thin coates of primer ....
Screenshot_2017-03-17-23-17-27.pngScreenshot_2017-03-17-23-17-34.pngScreenshot_2017-03-17-23-17-38.pngScreenshot_2017-03-17-23-17-42.pngScreenshot_2017-03-17-23-17-53.png20170317_225358.jpg
Well ive been seriously thinking of just going solid color due to not wanting to paint over grills, deck door, tuner. And if i paint the def leppard flag most likely it wont be very noticeable of what it is.
caution said:
Lookin' great! Excited to see a tribute to my favorite metal band.
Thanks!!!
Well i went with the colors but the actual flag probably wouldnt have been noticeable on front face so decided to just do colors. ;-)
Thanks!!!
What was the original plan? I know you said Def Leppard, but I really wasn't sure what you were planning.
baddboybill said:
Pictures aren't the greatest but it looks bad A$$ :-)
It came out very clean looking. Is all the electronics working?
Thanks!!!
The original plan was for the flag on front but i didnt want to paint deck door or tuner and figured most of it would be hidden anyway so i went with colors. But looks sweet and sounds amazing and is 100% after restore including replacing blown fusible resistor. ;-)View attachment 33757
I figured you were going to put their name/logo on the speakers, that's where all the space is :-)
Thanks!!!
The original plan was for the flag on front but i didnt want to paint deck door or tuner and figured most of it would be hidden anyway so i went with colors. But looks sweet and sounds amazing and is 100% after restore including replacing blown fusible resistor. ;-)Screenshot_2017-03-23-07-07-37.png
