Cassette door assembly - Sharp GF-9797
TheDogHouse
Got the box few days ago - Sharp GF9797. As you can see in the picture, the cassette door is little bit displaced.
When you jiggle it, it's certain that something has snapped off. Now, my thinking here was that the broken off part must still be inside the box, cause when I shook it I could here the part rattle inside.
So, I opened it, but I couln't find the missing plastic piece. It was the spring that was rattling inside.
Here is a picture of the damaged part of door assembly. That's the lower left corner of the door, viewed from inside.
I have to rebuild it and generate the missing piece somehow. Does anyone know what it should look like? What should be in there and is the spring I found from inside the box suppose to be in that assembly?
TheDogHouse
No. It's not intact, it's broken and it's missing somekind of piece of plastic. I'm trying to figure out what the shape of this piece should be, since I have to rebuild the hinge. And I'm also wondering if the spring I found inside the radio belongs to this assembly.
Anybody?
