big SHARP recordboomer needs help
ViennaSound
A few weeks ago i got this nice SHARP VZ-2500
It´s in pretty condition, except an little damage at the left speakergrill.
Radio and Tape works well, but the recordplayer needs help. :-/
This is the big monster:
The record does´nt start to turn!
When putting an LP inside, the tonearms only shaking a littlebit and some motor humming is inside.
When putting an single inside, the whole box shuts off after a few seconds!! :huh:
Maybe something is blocking?
The control lights are working
Are there some belts inside, that can be weak/broken?
Some other ideas?
Anybody owns the same box (and probs)?
Thanks for help. :bow:
these do have drive belts for the turntable and the might need replaced ,i would also check to see if it has a 45/lp selector switch.
Wow! Awesome find Roman! I actually prefer the look of that model to my VZ-2000. She looks pretty clean too, I'd bet it's the belt too, just like JVC Floyd said.
I hope it's a little easier to replace than the one on my models. Good luck!
