Does the belt for this boombox look correct? If the belt is supposed to be flat like this, is it supposed to be the same width as the pulleys? Or is supposed to have two square belts and if so how do I determine the width of the square belts?
Also, there is a bracket that is adjustable on top of the flywheel. Is the flywheel supposed to have some play up & down or do I adjust the bracket so that the flywheel has no play yet turns easy?
Thanks all in advance for your help.
