I finally got a C100f.
Turns out, I have bad a solder joint at the right amp IC. However, there's no reason to bother figuring how to completely remove the board for a repair as the Loudness lever knob won't come off. The rest came off fine. I'm guessing it was glued on at some point in the last 29 years. Anyone have any ideas? I'm trying not to dremel off something that expensive/hard to replace.
, once Diesel is on the job it doesn't give up 'til its work is done.
