antenna lubrication
Eric
I know with you guys I'm setting my self up for this one, but anyone know of a good lubricate........for antennas that don't slide all that well.
light oil to get them free --
then wipe off all the oil -
then use plain wax to keep them free sliding
Eric
What kind of Wax ira, like car wax or furniture wax :hmmm:
plain old clear color parafin wax --comes in a 2" x 6" x 1/2" bar --
get it at ace hardware --use a light coat -
its main purpose is to make things slide :-)
Johnny
I normally always polish mine first with Wenol, then take wax paper and rub them up a little, not fancy but works for me.. :yes:
MasterBlaster84
If your antennas aren't shiny smooth then first you need to clean them with a little 000 steel wool, they will buff right out with just a few strokes.
skippy1969
Yup,this is what I do too,then I take a little 3-N-1 oil on a rag and wipe the antenna with it. Then it is smooth action and shiny. :thumbsup: :yes: :-D
SINISTER
Banned
i always soak them in c.l.r. or lime away first just to get any corrosion or crap off them then lube them up :thumbsup:
