glue i have had even some of the wide band ones that i have never found that came factory on some boxes , i had to use a half of a wide belt because thats all i found , but i always use a bit smaller one that way its nice and tight and not slip and up to now i have not had any problems. so i would say you should not have any problems,, now that i remember my pioneer sk-95 uses a thick belt for the play to engage so the only one i had was a thin one so i put a smaller one to have enough tension and it worked and it still works good now i have to do that to my pioneer sk-900 which is asking for the same belt...
