Adding Amazon Echo Input 8190E
MikeS
Hi
i would like to add an echo input to my 8190 i want to mount it internally, this will give me access to DAB internet channels and Bluetooth
it will be powered by the 12v feed passing through a DC-DC convertor with a USB 5V output.
this will power the Echo input which has a 3.5 mm audio out, I want to feed into the RCA line in connectors
I don't want to have to drill the case, feed the 3.5 to RCA cable through and plug the jacks into the rear ports
it will look messy
does anyone know if you can solder onto the RCA board and if so where the connectors are?
Mike
You can pickup supply from the internal power supply you shouldn't need a dc - dc converter if you use a voltage divider, you can make yourself. Also this has line in so you could connect the output of your echo to this internally.
