The moment you know that the speaker foams need changing.
Hajidub
Yeah, foams going or incorrectly newly installed will metallic rattle that voice coil. Weird though how increasing the bass, the movement of the speaker, helped. Might get away, for a bit longer, by removing and rotating the speaker 180 degrees, either way refoam is suggested.
I have one that needs surround replacement. I replaced the speaker with woofers from center speakers of home audio but no match to the sound quality of those APM woofers. I will try to get those surrounds replaced.
Reactions: rivetmaster
Just out of curiosity, are those square foams easy to find?
Yes, they are available!
I don't like those foam types that go bad within no time. Imagine it is 2.0 mm thick damn foam.
I prefer the cloth-reinforced rubber type surrounds. Cloth/fiber
There must be a way to make those with a mold.
If a 3d printed 2 sided. Mold could be made you could use polyurethane as the actual surround material.
Reactions: BoomboxLover48
I meant dispersed fiber technology in rubber for surrounds.
Actually, fibers are dispersed in rubber compounds and that is the latest technology for making surrounds in high end speakers.
Synthetic polymers like polyurethane types comes second for durability and sound quality.
rivetmaster
New foams arrived today.
I had to be careful because the originals were glued with a thick bead of rubber solution. That had to be removed. I couldn't cut it with a blade because I was applying too much force to the edge of the driver.
My best solution was a pair of nail clippers.
They look good. I'll wait for them to dry before I give them a workout.
