Bit of a love-hate relationship with these boomboxes to be honnest (and oft it seems like its mutual lol).
Had a few of these and its a bit of a hit or miss, great sound but hell those engineers made some odd decisions...
Anyways after changing vu meters, bluetoothing, lighting a jumbo..had some butons and leds and bluetooths modules laying around so I thought I d use them on this Philips...
Found a place to put a basic 10 euro bluetooth (5.0 and quite decent, thank you Bezos) pcb, soldered some 3mm leds and wires instead of the integrated micro-leds on the circuit board, and found some room on the backplate of the philips to put a control button, the bluetooth status led and the bluetooth battery "charging) led, hardwired a basic pcb from a usb charger to the 220 inlet (fire hazard but did it cleanly), soldered an rca cable to the pcb of the boombox (aux), allowing both rca and usb to be unplugged to remove the cover - or if the case should have it...replace the bluetooth module. Backplace not being flat and having to put some insulation between battery and backplace I decided to use insulation to have a flat surface to put the module... and voila....integrated bluetooth
