M90 battery door options, other brands that fit.
10,670
168
40
WI
We all know of someone that had a missing M90 battery door. From our research here, these are the known other brands that fit.
Conion C100 (Korean and Japan models)
Conion C126 (and aka's)
Conion TC999 (and aka's)
JVC-RC838
JVC-RC550?
JVC-RC636?
Some 'kind of' fit options:
Monchito said "one of the panny 50 series uses a battery door that is almost exactly but you have to shave a little bit on both sides and prepare the bottom hooks so it will hook inside"
Also, I stumbled across a JVC RC-W210 EGG that looks to have the same battery door. The locking part of the upper latches seem to be sticking out a tad more than a M90 door but the location of the upper latches, lower slots, and the size looks to be perfect.
Can anyone confirm/deny?
10,670
168
40
WI
^ yes!!!!!
Actually I have a project I needed a M90 battery door for, so I took a chance on the W210 door because it looks to be correct.
5,768
276
It is not easy!
I think Joe or one of us should start a thread about compatible parts for boomboxes. :yes: :yes:
I was surprised when he told me the toggle switch caps of Panasonic RX5350 was same as RX5150. They were exactly the same!
14,130
108
Naples, Italy
BoomboxLover48 said:
It is not easy!
Not a bad idea.
Lasonic 975 volume pots are the same at the Wheely Dynasty HT 959
Not trying to hijack this thread, just sayin'
He'll yeah now that I know this I can take my RC 838 battery cover and put it on the M90 that there's no battery cover For thanks for the info
jimmyjimmy19702010
3,578
26
Sunny Brisbane, Australia
Wow, that's amazing they used the same battery door mould from a long since discontinued model!
Another couple of examples:
The Hitachi 3D7 and 3D8 battery covers are identical in size and colour.
The Hitachi TRK-9140 and TRK-9300 covers are indental in size only.
10,670
168
40
WI
I still can't believe it, what are the chances. I really thought I would have to mod the clips or grind the edges at least, but this truly fits with no mods and doesn't bind up.
:thumbsup:
Gaffer
27
53
Cool, now anyone got a w210 battrey cover sale. I need one if my Conion one gets busted after I try to get my battrey cover off off. It accidentally got glued in with a plastic resin I used to make a c100f foot. It leaked in and stuck the door shut.
