I've started dissassembly of my 2020 box as tape is not working, i have to replace belts, 2*square 5" and one dlat 9" if i remember correctly, but...
Somebody was doing something with it before (could be the reason i've fot it for free) so rubber idler is nonexistant, what size should i source? Any suggested replacement? (Aiwa, Akai,Pioneer??)
Also there is a loos wire that I'm bit concerned about, end of it seems like fell off the back of UV meter shielding? As only there i've found similar copper "fitting" perhaps somebody knows where it should be located?
Any info appreciated.
Thanks
Maciej![20210125_201618.jpg 20210125_201618.jpg](https://boomboxery.com/forum/data/attachments/35/35183-684aa96030221b248f4c2651cbd8fcb4.jpg)
![20210125_201550.jpg 20210125_201550.jpg](https://boomboxery.com/forum/data/attachments/35/35182-b5502b5ccb96b0d00dcbd3ed166d3363.jpg)
Thanks
Maciej
