* Pioneer Disco Robo speaker disassembly *
jimmyjimmy19702010
3,578
26
Sunny Brisbane, Australia
Right hand unit with refoamed drivers and new deck keypad:
There is a black button on top and bottom that the whole speaker cabinets pivot on. You can see the ones in the top without removing any circuit boards once you get the top panel off. From the bottom you need to take the plate off, remove the feet and a few other screws to get the plate off and same "button" is there. Press them both and it'll compress the axle it pivots on and it'll allow cabinet to slide out. It'll maybe get stuck on the pin that is the release button on the top of the cabinets, the bit that's under the press button that angles the speakers out......they kind of come out sideways. It's a tad fiddly ADC105E5-7F30-4E12-B805-E2F933E146FC.jpeg
See where my screwdriver is? Above it at 1 o'clock is the black "button" that is actually the axle. Press on that with a screwdriver or whatever while doing the same underneath and slide it out sideways
Better pic of the two axle ends in the top with circuit boards removed. You do not need to remove all this to get to them though
That black button:
Grills are a bitch to remove if he's trying to. They're glued in. Pray the glue has gone hard and brittle.
You will need to remove that black strap that's around the cabinets to get to 2 screws underneath it. Don’t remove the button from the cabinet that holds the strap, it's easier to stretch the strap over the holding button. You'd snap the button if you tried to get it out
👆 That's once you’ve removed the cabinets of course.
6,324
456
Cool, I don't think I've ever seen one of these disassembled.
Why are they called disco? I don't see any lights on them.
Styleking
899
25
28
Boston, MA.
Superduper said:
Disco as in disco-music machine, as opposed to (disco-lights). However, one guy in HK (doesn't everyone in HK have a disco-robo?) modified his so that his speakers flash (ala the mini kabooms). I guess his is a Disco Lite Robo now.
I believe it would be a Disco Robo Lite Norm... :lol:
