Crown CSC-350L Restoration & LED Mod
vermouth
54
12
8
Brazil & USA
I picked up a Crown CSC-350L on Craigslist for a steal, but it was in a very sad state. The speakers' foam surrounds were dust, the lighted panel was dead, and the input board had been worked on by someone who didn't know what they were doing, so the aux line-in was left only, and they completely broke the phono inputs. The tape deck's cover was also broken and the antenna was seized.
I was able to fix everything after about a week of work. I rebuilt the speakers and they sound incredible, and I devised a work-around to the lights by adding a carefully placed LED strip.
The end result is a giant, heavy boombox with hi-fi aspirations and great sound. I'm just waiting on some knurled aluminum knobs to come in to complete it, and I might add a tiny red led to the radio station dial if I can come up with something.
Before. I drove from San Diego to LA to rescue her
The speakers were dust. Contrary to popular belief, the 350L actually has two 5" speakers and two passive radiators, each in their own sealed internal enclosure.
I couldn't fix its old lights, so I added an LED strip that probably looks better than the originals. It took an hour of fitting to find the perfect spot for it to light the panel and have the shell still close. You have to run the strip (12V blue LED strip, 12-inch length) exactly as I show here or it won't work out.
Almost like magic, 12V is accessible exactly where you'd want it. You don't even have to extend the short length of wire that comes with the LED strip.
Run the LED's lead through here
IMG_20200207_022938.jpgIMG_20200207_023002.jpgIMG_20200207_023023.jpgIMG_20200207_160331.jpgIMG_20200207_160419.jpgIMG_20200207_160513.jpg
https://www.youtube.com/watch?v=iYjpQnuwH1M
vermouth
54
12
8
Brazil & USA
Thanks for the positive feedback, it's getting a lot of compliments in person too and I'm enjoying it.
The first of the knurled aluminum knobs came in and they look and feel great. I'm going with that style for the rest of the missing knobs too, and although they're a little more hifi than boombox, it works for the 350L I think. I'd rather have the originals for it, but there is no chance of finding those replacements I think.
Reactions: H3NK3L
vermouth
54
12
8
Brazil & USA
Those are brand new knobs I got from Aliexpress. You can find them on eBay and Amazon too but they're usually much more expensive there.
6,324
456
Since there's an acrylic plate over the numerals, you might be able to use just one light on each side of it, because the acrylic is designed to carry the light across.
Reactions: BoomboxLover48
muchkusblin
17
Moscow, Russia
Help! Need help with CROWN CSC 350. I'm trying to disassemble the boombox. Can't figure out how can i remove the cassette lid to ease the front panel.
AE_Stereo
732
116
43
Abu Dhabi, UAE
I saw this post today only.
I was about to say the same, just need to fit one LED each at ends of the acrylic plate perpendicular to the edge. Just try by holding a LED with your hand on the edge of the Acrylic sheet and see the magic!
Reactions: vermouth
cakeman
10
Victoria, BC, Canada
Never hurts to try.. Ive found that on longer pieces of acrylic though the effect, of course, fades enough that you get uneven lighting when you get to the middle of a tuning dial, for example.
Works well on like VU meter covers etc.. its been a number of years since I last did it though.
Have you found it works well on longer pieces?
Reactions: vermouth
