Crown 850 tweeter issue
label321
97
8
Hello everyone,
I have a Crown 850 with it seems to have a left tweeter thats is very weak.
And it seems that the left channel is weaker than the right.
Also if i turn the boombox on you hear crackling noise,
I tried the rec bar clean but no luck so far.
I don't know what couse this problem.
Hopefully someone can help me in the right direction.
6,324
456
The crackling is very common with that model, sometimes it lasts 20-30 seconds. It's most likely a bad capacitor.
label321
97
8
Do you know wich one that wil be?
label321
97
8
You never know which capacitor
I must open it en take a good look.
I am not great on that area so i must find a guy that can recap the whole thing.
there are a ton of caps i saw on a google picture.
