Crown 850 deck help!
docs
2,558
381
United Kingdom
Hey all, I'm a busy rabbit this week with more boxes open than Deal or no Deal.
If anyone could help me with this one I would appreciate it.
The Crown 850 is open to take a look at the belts and deck. Basically the deck is playing "warbly" and not steady, does that make sense ?
It kind of sounds like the speed is off. The belts look ok to be honest and the FF/REW functions perfectly.
Would anyone happen to know if it is adjustable internally or does it sound like I have a knackered motor ?
docs
2,558
381
United Kingdom
On second look at the belts, hmmm I think one of them is an elastic band :lol:
And I think that the capstan belt isn't a flat belt but a long square belt.
Back to trying to find the correct measurements for this deck :sad:
Anyone any clues please ?
docs
2,558
381
United Kingdom
Yeh had to wait for a little charge in the camera battery hehe. I played around a little more and it does seem like it is just the belts. Phew.
The top black one is a new one I just added to try. The white one :-/ a poor kid has lost his elastic band, he used to play with, for the last 25 years. I'm sure that should be a round belt, not flat.
docs
2,558
381
United Kingdom
Yep thought as much. I need to find someone who may know the correct belt sizes so I can get to ordering some.
The ones I have won't fit, or for that long are all flat.
Failing that I'll have to order 10 belts of different sizes or so.
there is also a speed control screw under that blue sticker on the cassette motor.
docs
2,558
381
United Kingdom
Oh great I did wonder but thanks a lot for confirming that.
I tried a few various belts on it, one was really too tight but the warbling went away, it just played a tiny bit slow.
Once I get the new belts on it I'll see if that screw will straighten this sucker out.
Cheers.
monchito
4,602
11
pythonville florida
i bit tight as long as everthing continues to work might be ok just adjust the speed on the motor,, but if its really tight where you have problems with deck not working then that is a no go and would not recommend using it like that,, remember over time with use the belts will stretch a bit, i have put belts just a tad smaller and its worked as long as its not excessively tight it will cause fast wear on plastic parts not good....... :-)
Too tight is an excellent way of wearing out the bearings including those in the motor, and also permanently skewing the rubber motor insulator mounts. Don't do it. Get the right belt or none. The first time you need to find an obsolete motor because it's burnt out or starts squealing will be the time you wish you didn't overtension the belts.
PostEnder
149
Southeastern U.S.A.
Over six and a half years later, Dave, did you get the right cassette-deck belts for your Crown CSC-850 while avoiding the ruinous experience of installing too tight a rubber belt (or too tight a set of rubber belts)?
fromNKLwithlove
307
FIN
Wondering the same thing.. What are the right sizes? My belts were goo.. :blush:
5,763
275
Make 2 to 3 loops with a cotton thread on the wheels the belt is running, and then hold it tight, glue the end with nail polish. Let it dry. Now make a cut to take the thread out. Then measure the length. Order a belt 95% of the length you measured. It worked well for me. ~ Royce
MyOhMy
2,509
7
Sleaford, Lincolnshire, UK.
Ah, simple but genius! (Copied into my 'Hints & Tips' txt doc.)
PostEnder
149
Southeastern U.S.A.
Hey, Royce, like our MyOhMy indicated with her reply, that's quite some belt-sizing hack (or "improvisation") that you recommend. Uh, when you speak of "a belt 95% of the length you measured," do you mean an intact (uncut) cassette-deck belt positioned so its uncut strips are straight and parallel, almost touching one another? (Somewhat like what one sees in the image below from the WJOE Radio website):
Or do you mean that the tape-deck belt to be replaced should be cut (obviously no longer usable as a tape-deck belt) and laid out flat, with its ends in opposite directions for the measurement?
