So as I am working on the two Conions to make one good one out of them, I have to realize that both have one and the same problem.
The power up just fine, alarm works, left VU meter goes to full when on radio.
But other than that - that's it
No radio reception is indicated, the volume does not seem to affect the background sound of a humm/hiss.
The stereo/mono switch makes a small cracking come out of both speakers.
I cannot be the first one with this issue since both of the boxes have this problem .
PLEASE help!!!
I was thinkign it could be a bad record bar, a haircrack on a board or something like that...I hope it is not the crack on a board - but isn't it very unlikely since both have the same issue???
Any input welcome - otherwise I'll go through cleaning record bars and disassembling these things until I find anything visible that could be the cause .
I was thinking a loose contact on the main board maybe? I don't believe both tuners are broken.
And I don't believe both amps are blown either .
There must be something so please help me with your experience!
Thanks a lot!
Max
PLEASE help!!!
Thanks a lot!
Max
