Substitute case screws from ebay.
rivetmaster
53
69
United Kingdom
I'll post this here on the off chance that someone is struggling like i did to find proper case screws.
I found some 50x3mm self-tappers that perfectly replace the ones in my Panasonic rx c60. They are silver and the threaded part is longer, but they do the job.
Here on ebay:
Or search for:
Screws Self Tap 3mm x 50mm Pitch 0.50mm Per 20
Reactions: Spax and Brutus442
6,327
457
Those heads look smaller than the original. Might be a risk of breaking through the end of the screw post.
Tinman
518
264
You might want to grind the pointed tips down. The blunt tip acts as a stop in case the screw bottoms out in the plastic when installed in the wrong tower. If you leave it pointy, there is a posibility that it won't stop if it bottoms out and you'll end up with a whole hole where there was none before.
I can confirm this but luckily my screws weren't long enough to fully poke through.
However, they did end up leaving some annoying dimples.
