Unless you are sure you shorted something out . it may just be the record bar is not lined up right and it's not letting the audio signals pass through like they should. I had this happen before when I hooked the connecting rod to the wrong slot on the record bar.
Thank you for that , but afraid thats not it...unless i broke something in it... Thouroughly cleaned and switched (manually) a hell of a lot of times, even during manually switching (pullint it out) nothing happens. I cant feel any sideway movement in it, it pretty much goes straight in and out, cant wiggle it.
When powered on :
- both vu meters react normal - strike out full then go back
- tape works fine, REW, ff, play, PAUZE but no signal (AMSS not working)
- no tuner
- no dolby, led not lighting up
- no line in
- no AMSS , but AMSS leds do light up
- no humming on speakers, nor on headphone : only the slight click when powered on/off but barely noticeable
So I think,, abouy 95pct sure...I shorted something....somehow...and the only way that could have happened to all logic would be that metal connector touching those voltage pins. No smoke or anything..unfortunately (makes things easier to figure out lol). Just hit REC to see if I connected it correctly, REC light came on and all the rest went dead (except for the tape deck ), no sound no radio no nothing. Which makes me think at 95pct certainty that the rec bar metal thing touched one or more of those pins. My gut feeling kindof says : something isnt getting power
(5pct : I ll try to remove the rec bar and clean it when its out, there seem to be no cracks in any soldering on it, but a reflow + out of the boombox cleaning may do the trick)
My first guess was : hell you pulled on a wire and it came loose so something isnt getting powered, but all is still where it should be, soldering is fine, no loose wires.
Second guess : you messed up the rec bar, somehow pulled too hard on it, ... but...I dont think I did, I was quite careful to only put on the hook on the rec bar as final manoeuvre and did so without pulling on it, only pulled on the huge metal connecting thing.
I dont have a service manual
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
All pins seem to have voltages (8,47 V 11,96V and such, which to me seens normal), except for the pink ones, no idea what those do or or supposed to feed. So before I go changing power regulators and such....I prefere asking the more wise
here are the pictures of the huuuuuuuuge metal thing that goes all the way from the left of the tapedeck to the rec bar
RED : path of the metal thing going from tape deck to rec bar
BLUE : left : where all those pins are - right : the rec bar hook (not very visible but its the square white thing)
![IMG_20231129_172239.jpg IMG_20231129_172239.jpg](https://boomboxery.com/forum/data/attachments/41/41822-8d16fe62b91fc12c4c80bb58d168762b.jpg)
